np203 help
Discussion in 'The Garage' started by the187ip, Apr 25, 2006.
  1. the187ip
    the187ip Newbie
    Apr 23, 2006
    california
    i have a np203 in my 75 k10 4X4 and i took the shift asmmbly apart and cleaned it and it still gets stuck in 4lo and 4loc and when i get it into hi it wont shift out does it need a rebuild or what? plz help
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I cleaned my shifter yesterday, but didn't want to disassemble it. I took the thin tin covers off and used carb cleaner to blast the dirt out. Once clean I used some white lithium grease for lube. One shifter moves fairly easily, while the other hardly moves.
    Sorry, I can't help you, but I'll give the thread a bump.
  3. gmcburb1965
    gmcburb1965 clever user title
    Oct 29, 2005
    61
    Colorado Springs
    Just a thought, but have you tried adjusting them?
    Disconnect both linkages from t/c
    Align both shifter arms to neutral
    Put t/c in neutral
    Put 5/16 drill bit in the hole through shifter (bottom center)
    Adj nuts until the linkages go in their holes
    And don’t forget the drill bit
