NP203 install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Nov 14, 2004.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Is there a good way to get that thing back into the truck? I have one of those tranny jacks that sits on top of a floor jack. If I put the tcase on the jack, I cant get it under the truck. I have the truck jacked up as high as I can. This thing is just too damn heavy. Any help would be greatly appreciated.
    AW
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I replaced 8 203's in my truck in 8 months... my suggestion would be to find a 205 and save yourself hassle in the long run.
    If that is not an option, then you can also remove the pass seat and tranny tunnel cover and lift the case up into positon from the top side w/ an engine hoist, or rent/borrow a low-rise tranny jack.
  3. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    This is not a one person job if you do not have the right equipment. I just went through this. Know anyone with a motorcycle jack? Makes life so much easier, and you can do it by yourself.
    If not get a buddy or two to help you.
  4. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I had help, its just not possible to lift that thing up from ground level when you are on the ground
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I just got done pulling and reinstall my dads TH350/203 combo(pulled it as 1 unit and reinstalled it as 1 unit)using one of these. They work REALLY good, can also be used for axle swaps /forums/images/graemlins/thumb.gif
  6. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Ill see if I can borrow one
