NP203 oil
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Sep 27, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I'm going to change all my fluids this weekend and was wandering which oil to use in my NP203, everything I've seen here says to use exactly what I use in the motor, but the guy at the parts store says to use nondetergent 30 weight to keep the chain from streching. What do ya'll think? Also what should I use in my axles?
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I don't think that sounds right...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I think you should go back to that guy at the parts store and get an explanation.
    Use motor oil in the NP 203, use whatever you have on hand .
    Use gear oil in the diff's, if your in the desert southwest use 80/90W-140, anywhere else use 80/90W.
    Good luck
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    The Haynes manual recommends: NP203 10w-30 engine oil
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  5. Jonathan
    Apr 14, 2001
    293
    He said something about the detergent in regular motor oil would make the chain stretch easier.
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Non detergent is specified for all non-engine type stuff.
    Worm gear winches and spur gear winches(Warn8274)
    specify non-detergent.
    It's not hard to find, the 99c crap at Family Dollar is often non-detergent.
    You do not need 75w gear oil in a chaindrive case. 10w-30 will work if you can't find straight 30.
    Poundin' the ol "pavment"!
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    What about the NP208? Is there anything special I should use?
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  8. RedDwarf
    May 9, 2001
    816
    Yup. It takes ATF
    You already knew that right?
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea, I just wasnt sure if there was anything else out there that works better.
  10. RedDwarf
    May 9, 2001
    816
    Well, how about synthetic ATF?
    Runs cooler, amybe even quieter(NP 208 sure is noisy in LOW aint it?)
  11. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Next time I change mine I'm gonna put in FA instead of Dexron and see how it does - being a little thicker, I'd think it'd work better - atleast down here in the land of heat.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  12. Jonathan
    Apr 14, 2001
    293
    So, I should use straight 30 weight
  13. Executioner
    Feb 22, 2000
    1,530
    I hear you, make sure you don't take a bath with that parts guy ! I really don't think it will make a difference
    for a NP 203, and say 200K miles, at say an average oil drain/refill of every couple of years . A clean chain
    should not streacht, but if the oil breaks down, and fills the chain up with gunk, what would happen ?
    Really just use whatever you have, or buy whatever is on sale/cheap.
    Good luck
  14. RedDwarf
    May 9, 2001
    816
    Get the non detergent, you can use 10-30, 10-40, or straight 30.
    You don't need the detergent because you don't have contamination of the oil, so it will only cost you lubrication.
    I don't think the detergnet will hurt the chain though as they are similar to a timing chain and it obviously doesn't hurt them....
  15. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    10-30 motor oil. 99% is detergent oil. I run valvoline in everyything. Get part #129 valvoline.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  16. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    hmmm... mobil 1 in the NP203!! theres a thought.
    mike
  17. RedDwarf
    May 9, 2001
    816
    Why the heck not?
    Should last forever.
    Unfortunately, it will probably make the NP 203 last forever too...
    Still Poundin' "pavment" after 275 Posts!!!
