NP203 Part time kit.. ther's 2 kits?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Mar 12, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    NP203 Part time kit.. ther\'s 2 kits?
    I went to order my part time kit and one's 250 and one's 50 bucks... one is the shaft kit and the other ids the small gear kit... can i take the cheap oute and do the 50 dollar one?
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Re: NP203 Part time kit.. ther\'s 2 kits?
    You can get the cheap one and it will work. However, like most everything the cheaper one is excatly that. The shaft is the ideal way to go. I put the gear type in mine. Only cause I plan on building a Doubler. If you plan to stay with the 203 I recommend getting the shaft.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you can pick up a np205 w/adapter for your tranny for 250, go with the cheap one OR keep a look out for a np205.
    ARQ.
