np203 part time milemarker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by supernaut, Oct 9, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    I ordered the part time kit from Milemarker that includes the replacement output shaft and removes the differential altogther. In a few weeks I'll be installing it. Any others who have done this have tips, recollections of tough spots? I have read through the review of these kits here on ck5.
    ( http://coloradok5.com/milemarkerpt.shtml ) It's great and packed full of good technical info.
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Did the same thing in mine. The article you have will walk you through the process. Pretty simple, just remember to engage it once in a while to keep everything lubed.
  3. supernaut
    May 2, 2005
    94
    Seattle, WA
    Hey thanks a lot for the reply! It's good to hear someone else has done it. I'm anxiously awaiting my kit now.
    In the instructions:
    Anyone know the part #? I'd like to get it ordered asap.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I put in the Mile Marker Solid Shaft kit when I rebuilt mine. Made a noticable difference where slack in the output is concerned. The hardest part is taking the time to set your endplay properly. As has been mentioned, make sure to engage your case every few hundred miles to keep the output bearing lubed. Get in the habit of engaging it for a bit every time you fuel up. That way you don't forget as going to the station reminds you to do it.
    Oh yea, don't forget to slide your speedo gear on or you'll have to take it back apart. :doah:
  5. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I just hit up the Chevy parts counter. They looked it up and had it in stock.
