NP203 Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cj7jeep81, Feb 17, 2003.
  1. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    I have a 1978 Chevy K-10 with a np203 transfer case. It always sticks in 4-Hi. If I try to put it in any other gear, it either doesn't engage or pops out as soon as I move. I am guessing the t-case needs to be pulled apart, and possibly rebuilt.
    Does it just need to be rebuilt, or is it worse? If it needs to be rebuilt, how much does this job usually run? Thanks in advance.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Check the shifter for alignment on the shift rod.
    Bill
  3. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    At the risk of sounding really stupid, where would that be? Do you have any pictures?
  4. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Loook under your rig by the Xfer case the 2 rods should have a hole in them. place the shifter into Neutral then try place a drill bit into the holes at the same time.If the bit doesn't fit through both at the same time, adjust the linkage nuts till the holes are lined up perfectly so the bit slides through both rods!
    Bill
  5. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Thanks a lot!! As soon as it warms up some, I will check it out.
