np203 question(emergency)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Nov 8, 2001.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    Wassupi,
    I just blew out my front driveshaft, I am supposed to be going out of town tomorrow, roughly 250 miles round trip. Is it OK to pull the front driveshaft and run the transfer case in High lock for the trip. I have an NP203 w/turbo 350. Just want to make sure everything will be lubricated correctly. Thanks for the help guys.
    If in doubt, gun it.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if you have the part time kit yes. i drove for 2 weeks in w/o a front driveshaft. if full time i have no idea
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  4. 76K5
    Jun 23, 2001
    99
    North Carolina
    Its full time, but wouldn't it stil be okay?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Running in High loc with the front driveshaft removed should be OK. All the lock postion does is lock the internal differential. Have a great trip! [​IMG]
  6. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    But does he have to run it in high lock? Why not just in high? Just curious as to why.
    Eric78K5
    K5-Because Size Matters!
  7. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    The high position is like having an "open" differential and trying to move the Blazer with one tire off the ground.
    The lock position is like engaging and ARB on the differential which would make the tire on the ground move.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Make sure that NP 203 has motor oil in it, not gear oil, not ATF.
    Good luck
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    why motor oil and not gear oil? also what is this "Hi-lock" like and ARB talk? WTH is an intrenal diff lock?
    -Zakk
  10. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    B/c 203s uses Motor Oil NOT gear oil. If you have a 203, I hope you put motor oil in yours.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
