NP203 Question
Discussion in 'The Garage' started by chalet2506, Jan 15, 2007.
  1. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    I've searched around and haven't come up with a good answer. I've got a part time kit in my 203(po installed it, not sure who made it) and warn premium manual hubs.
    I understand what the new shift sequence is, and I understand how the 203 worked before the part time kit. L/H Loc for off road, L/H for highway. Difference's being that front and rear d shafts are locked at the same speed when operating in loc.
    BUT, I can't find any info on whether or not the drive shafts are still "loc'd" or if the t-case is operates as an "open or limited slip" mechanism in 4WD with a part time kit installed. Reason I'm asking is I've got 32's on the rear right now and 31's on the front. It's icy down here and would probably be bad medicine to run it in 4x4 with different size tires if the t-case does still lock.
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Did you read this write up and the Mile Marker installation and function?
    http://coloradok5.com/milemarkerpt.shtml
    If you have the mile marker kit installed then your 203 output no longer has a differential function. When your in 2-hi or 2 low position then only your rear driveshaft is turning.
    If the hubs are unlocked and you engage 4hi or 4 low then your front and rear shafts are turning but the front hubs are not locked in so the front wheels are still undriven.
    With the mile marker kit you have to engage both your case and your hubs to drive the front tires.
    Whatever you do don't engage 4 wheel drive with mismatched size tires.
  3. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    I read it, but I guess I'm mentally gear challenged. With 2 different tire sizes, hubs locked, in 4 high, is there enough slip to allow for the difference in tire diameter between the front and the rear?
    The way I understand, before it was converted you could with the t-case operating in just low or high, not loc'd operation. Probably not a good idea, but it would work.
  4. Cricket
    Nov 29, 2004
    8,224
    Colorado
    I wouldn't try it but someone may have a different perspective on it.
  5. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    In 4 high there is NO slip between ends. in 4 low there is NO slip between endsin 2 high and 2 low, there is NO drive to the front end.
    the difference between 31's and 32's is great enough that you should not use 4wd in anything but mud or deep snow.
  6. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    that's what I was looking for. thanks for the info.
    Kurtis
