np203 range box idler removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by michaelm, Dec 18, 2001.
  1. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    is it a light press fit?
    I didnt see anything holding it in, and a few whacks with the deadblow didnt seem to move it.
    TIA
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Its a press fit on one end, i think the back end, that end of the shaft is slightly larger than the front, so you feed it in through the back, or drive it from the front to the back to get it out, that is if i remember correctly. Anybody want to confirm this? Maybe if i go lay in a puddle of 30W i'll remember for sure?
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  3. ponderingjunkman
    ponderingjunkman Registered Member
    Dec 6, 2001
    14
    Cairo, NY
    Just took mine apart, and reassembled it. It is a press fit, but not light! A 5lb lead hammer moved it quite well. Sharp blows and a beefy drift are needed.
    No Replacement for Displacement
  4. michaelm
    Feb 2, 2001
    872
    thank you
    I will beat it to death then,
    maybe I will press it out
