np203 rebuild... can I do it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, May 23, 2001.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I burnt out my tranny a couple days ago. So I dropped the tranny and x-case, and took the whole thing into a guy to have him rebuild my tranny. I wanted him to look at the x-case also because I could hear it grind when I'm crawling up a hill or anywhere else there is a lot of pressure on the front axle. So he looked at my x-case and said that my chain is worn and that would explain the slippage and grinding noises. I dont have much money (all of it is already going twards the tranny) but I do have time, so I was thinking can I rebuild my transefer case? I have rebuilt engines before and feel confident doing things mechanicly, but draw the line at auto trannys. Does the case require any special tools or skill so rebild? What parts do I need or is there a kit?
    Grind it 'till you find it
  2. Grim-Reaper
    7,385
    Atlanta
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I dont know about the 203, but Standardtrasmission.com has rebuilt kits. I called about my 241 and the kits comes with seal, rings, bearings for like 199 and the chain was seperate for about 70.
    As for doing it, I haven't jump in and done it yet, but from what I've heard they aint to bad.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Hey Grimmy the link says page not found. Can you double check it and let me know. I'd like to check them out as well.
    thanks...
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I have done many, I am in Tucson and will offer Tech help if you need it. Try and buy a NP205/NP203 manual
    from a Transmmision supply house.
  6. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Exec,
    Can you recommend any one in particular to buy TC parts from in the Phoenix area? Do you have email?
    azblazor
  7. Executioner
    Feb 22, 2000
    1,530
    No recommendation, sorry I am new to the Desert Southwest, If your on a budget mail order can not be beat!
    Send PM and I will give it to ya.
