NP203 rebuild/replace/jury rig opinions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fredekr, Feb 19, 2003.
  1. fredekr
    fredekr Registered Member
    Jul 12, 2002
    92
    Colorado Springs, CO
    My NP203 pops out of 4hi and 4lo. It holds for a bit, but always comes out under hard load/unload cycles. It's easy to hold it in gear with slight pressure.
    It's got a part-time kit in it from a previous owner.
    The linkage is correctly adjusted.
    I have no oil leaking that might indicate worn bearings.
    No mechanical or other shifter interference as far as I can see. Easy shift get into and out of various ranges.
    So my conclusion is that the shift fork(s?) are worn. I don't have a diagram of the xfer case. (It's not in the 77 factory manual!!)
    My predicament: I don't have a garage. The nearest one I can borrow is two hours drive (Boulder to Colorado Springs).
    Questions:
    1. How hard is the xfer case to pull? I don't have a tranny dolly.
    2. How hard is it to replace the shift forks? It would have to get done in a weekend which is obviously a problem if I discover anything else wrong that I'm not prepared for. (In fact, even that would be outside since I have a camper on this -- ~8ft tall)
    3. Should I just get a rebuilt one rather than do it myself consider my time/space limitations? /forums/images/graemlins/deal.gif Or maybe god forbid take it to a shop and really get reamed? /forums/images/graemlins/eek.gif
    4. Or should I just jury rig something until it gets worse? /forums/images/graemlins/rolleyes.gif
    Thanks for help and opinions!
    cheers,
    Kevin
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I am on my 5th 203 in 1 year. They are a pain in the @$$ to remove because they weight just over 200 lbs I think. Next time mine comes out it is getting a 205.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Wow I don't see how you can brake so many 203's, are you sure you are not running it locked on the street?
    Anyway to the original question, you should be able to get a 203 from Pick n Pull if you have those in your area for $100, they are a b***H to handle but a used one should be fine.
    I put mine in with the help of a jack and 2 buddys helping to hold it straight.
    It's easier than messing with the rails and faster.
    I did mine off/on in 1 hour.
    /forums/images/graemlins/thumb.gif
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Well, 2 of them I have blown up, 1 had a bad chain when I put it in, and 1 got taken out cause it was the 1/2 ton A/T model and I needed a 3/4 ton 4spd model.
  5. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Why don't you just dump the full time 203 and get a 205 amd convert your hubs to locking hubs...
    Stronger and WAAAAy better 2wd performance and milage..
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  6. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Won't the output shafts on the tranny be wrong for him to put a 205 in? I have the same problem, ratchet strap around the center console works wonders. I tried putting a washer in with the detent spring to see if that helps, but I'm having bad engine problems before I had a chance to test it. See the ORD board for info on putting the washer in.
  7. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My 203 already has the part time kit and the locking hubs. Yes, I would love a 205. Yes, I will have to redo driveshafts, but that is not a big deal. The bigger problem is finding a reasonable 4spd version 205.
  8. fredekr
    Jul 12, 2002
    92
    Thanks for the washer idea; might try that in the meantime. Could you point me to the ORD thread? I searched and couldn't find it.
  9. fredekr
    Jul 12, 2002
    92
  10. fredekr
    Jul 12, 2002
    92
    Bummer, the washer trick / increased detent tension didn't seem to make much difference for me. Looks like I'm looking at the jury rig or replacement options...
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If ya want to, you could get a 205 and do a ORD Doubler
