NP203 shifter position
Discussion in 'The Garage' started by mkinnunen, Oct 3, 2004.
  1. mkinnunen
    mkinnunen Registered Member
    Aug 29, 2003
    43
    Albuquerque
    The shifter controls two levers at the TC. Which one is which? Big one in the back and smaller "S" shaped one in the front. is one of them 2X/N/4X and the other Hi/Lo?
    Please let me know.
    Thanks,
    Michael
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The outer lever is the range selector , the inner is the lockout lever . /forums/images/graemlins/thumb.gif
    Found on Autozone.com . they have new guides that someone mentioned a couple months back .
    The 203 full time 4-wheel drive transfer case is the only one on which linkage adjustment is possible.
    1.
    Place the selector lever in the cab in the Neutral position.
    2.
    Detach the adjustable rod ends from the transfer case levers.
    3.
    Insert an 11/64 in. drill bit through the alignment holes in the shifter levers. This will lock the shifter in the neutral position with both levers vertical.
    4.
    Place the range shift lever (the outer lever) on the transfer case in the Neutral position.
    5.
    Place the lockout shift lever (the inner lever) on the transfer case in the unlocked position. Both levers should now be vertical.
    6.
    Adjust the rods so that the linkage fits together. The indicator plate can be moved to align with the correct symbol.
    7.
    Remove the drill bit.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Hey, I have that shifter box and rods that I told you about when we met up, if you need them let me know /forums/images/graemlins/thumb.gif How did that tranny work or did it, curiousity is killing me /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    Krennen
