NP203 to NP205 Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Crispy, Jan 7, 2002.
  1. Crispy
    Crispy Registered Member
    Jan 7, 2002
    6
    Hey,
    I have a 76 GMC Ex-Canadian Military 5/4 Ton. The truck has a 1 Ton Rear End and a Dana 44 HD front End. It presently has a GM NP203 Transfer Case, which has seen better days. I am changing it to a GM NP205. I know that I will need the adapter plate for my Turbo 350 Transmission and new Drive Shafts due to the different length of the Cases, and different Collar. The NP203 is a full time Case where the NP205 is only part time.
    My question is this: Do I have to install Lock Out Hubs to run the NP205? The NP203 does not use them.
    Please reply only if you are sure.
    Thanks,
    Chris
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    No... you do not need manual hubs - but I would recommend them anyway.
    Marv
  3. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    You do not have to install lockout hubs. You currently have drive flanges that keep the axle locked in. The advantage to lockouts is that the axle could be disconnect from the tires while in two wheel drive. This would get you a little better gas mileage.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  4. Crispy
    Jan 7, 2002
    6
    Thank you guys!
    Chris
