Np203 transfer case help
Discussion in 'The Garage' started by Gmck2500mudder, Jul 21, 2006.
  1. Gmck2500mudder
    Gmck2500mudder Registered Member
    Jul 21, 2006
    31
    Canada
    Hi, I have what i believe to be a 1980 GMC k2500 pickup. I have a sbc 350 and th350 in it. The rear end is a 14 bolt gm and the i think the front is a dayna 44. It does not have manual lockin hubs. I am loooking at converting it to part time 4x4. Does any one know of a kit for this specific truck to do so and which setup of locking hubs i need. All the descriptions say that they are for 1973-1979. I am very frustrated and any help or suggestions would be greatly appreciated. Thanks a lot
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Are you sure you have an NP203 in your 1980? I would suspect that you have an NP205 with auto hubs. If this is the case, you simply swap out the auto hubs for some manual hubs. Somebody with a later model rig can pipe in on this one.....
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    what is written on your shifter knob?
  4. Gmck2500mudder
    Jul 21, 2006
    31
    Canada
    There is just 4x4 low range, neutral and 4x4 high range
  5. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Its not an '80 if its got a 203. All '80 model year had 205s regardless of engine and transmission combination. And it'll be a 10bolt if its an '80. You likely have a '79 or earlier. the vin # can be decoded to confirm the year.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You got a 205 and auto hubs it sounds like. It is def not a 203.
    Ira
  7. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
