np203 transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77k5, Oct 18, 2000.
  1. 77k5
    77k5 Registered Member
    Oct 16, 2000
    9
    I was reading on of the posts and it said something about using 10w30 motor oil instead of gear oil, I have gear oil in mine, that is what was in it. I could find anything about it, could some point me in the right direction and I'll need to drain my case but I didn't see a plug where it would drain.
  2. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Actually you should use 10w-40. See http:/www.off-road.com/chevy/mm-np203/. This info was provided to me by Boss and Wheels from COK5
    Peace
    James
  3. James
    Jun 22, 2000
    179
    Castaic, Ca
    Sorry. Forgot to say. Provided it is full time 4wheel drive.
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    To drain it, you will find some bolts in a circular pattern in the rear of the case. You need to remove one or two of the bottom ones.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  5. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I thought it was 10w30 for an np 203 that is still full-time.
  6. 77k5
    Oct 16, 2000
    9
    The case has a part time kit in it, does that make a difference?
  7. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    No, the oil slinger is still the same and with gear oil, some parts won't get lubed properly
