np203 trouble
Discussion in 'The Garage' started by guz71, Mar 30, 2007.
  1. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    My rear driveshaft self destructed the other day and it chewed up the rear yoke on the transfer case. I can not figure out what socket i need to remove the nut that holds the yoke on???I drove all over town looking for it and even went to the dealership to see if theyd do it real quick for me but no luck. I know its big, bigger than 1-1/4 i think and it has to be a THIN wall socket.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    3/4" drive 1-5/16" socket
  3. guz71
    Sep 17, 2006
    387
    lubbock/houston
    thank you:bow:
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Only one thing, I bought a 1 5/16" Craftsman socket, but it's OD was too big to fit into the yoke. I then went out and found and S&K import one with thinner walls, hoping it wold fit, still no go, I had to put in in the lathe and turn down the OD a bit to make it work. So, my point is, try and find one with the thinnest walls you can find, or get out the grinder.
  5. guz71
    Sep 17, 2006
    387
    lubbock/houston
    I found a pretty thin one and I measure the diameter of the yoke and i think it will fit, if not Ill whip out my little buddy:D
