NP203 Twin Stick Questions.
Discussion in 'OffRoad Design' started by Iron_Weasel, Mar 29, 2005.
  1. Iron_Weasel
    Iron_Weasel Registered Member
    Mar 29, 2005
    70
    New Mexico
    I'm looking to buy the NP203 twin stick that ORD makes, but I have a few questions about it.
    1) What's the lead time on it?
    2) Does it bolt right up to the existing transfer case mounting location?
    3) Are there any modifications that will need to be made to allow use of the twin stick design as opposed to the factory stick?
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    As far as I know, the twin stick is for the 205, not 203. When used with a double, the twin stick or the triple stick can be used. However, only one "stick" goes to the 203.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    There is a twin stick specifid to the 203 that ORD makes also.
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    That tells you what I know :grin:
  5. Iron_Weasel
    Mar 29, 2005
    70
    New Mexico
    ORD has one for the 203 that runs about $170 according to the site. Though I don't know how up to date the site is. It must not be a very popular item....I was figuring that someone on here might have some personal experience with it.
    I'd like to get an answer to a few questions prior to plunking down almost $200 and then finding out I have to modify something to make it work.
    ORD has a few things that I'd like to get ahold of in the near future...but I like to know what I'm getting into before it gets ordered.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The 203 twin does bolt up in the factory location, it's a pretty easy install overall.
    Lead time is about 2 weeks at this point, maybe a bit quicker depending on order timing. We build most of our parts in batches so lead times vary depending on where your order hits in our build cycle.
    There are no other modifications required, it just bolts on and give you independent control of the gearbox and differential.
    One other nice feature is that this shifter is basically the same as our Doubler shifter so if you do a Doubler later, there's very little work to do on the shifting.
  7. Iron_Weasel
    Mar 29, 2005
    70
    New Mexico
    Good to hear answers straight from the man himself. :bow:
    I'll order mine on either the 20th or 21st, any idea on where in the build cycle those dates will fall?
  8. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i think im gonna need one also im only getting 3 out of 5 of the shifting pattern from what i hear the np203 shifters go out alot. will the twin stick solve this problem?
  9. Iron_Weasel
    Mar 29, 2005
    70
    New Mexico
    If it's a problem with the shifter or the linkage and not the transfer case itself, then it should solve the problem.
    My shifter was so filled with crud that it didn't work for anything. I disconnected the shifter linkage and it worked fine.
    So as soon as I get paid, I'll be ordering a NP203 Twin Stick.
  10. chromewontgetyouhome
    chromewontgetyouhome Registered Member
    Aug 1, 2004
    69
    Big Island, Hawaii
    I have a 203 twin stick from ORD, and it is 100% better than the stock one. It was easy to install, the only mod I had to do was trim a little metal around the floor board. Shifting the transfercase is a cake walk now, and when I decide to get the doubler, all I need is a longer link to reach the 205. :laugh:
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Throw up some pics if you could
  12. AlaskaFJ60
    AlaskaFJ60 Registered Member
    Jul 4, 2005
    9
    Eagle River Alaska
    can you post a picture of it
  13. AlaskaFJ60
    Jul 4, 2005
    9
    Eagle River Alaska
    on the way
    My twin stick for the 203 is on the way ,,,,yipppie , that is the last part I need for my project
