NP203?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jms0945, Sep 13, 2001.
  1. jms0945
    jms0945 Registered Member
    Aug 22, 2001
    64
    Huntsville, Alabama
    can anyone tell me anything about the NP203?
    weather it is a good transfer case or not?
    How tough?
    and if a good price for one off of an 1980 is $100
    or $250 for both the orig tranny and transfer case
    thanks in advance
    Michael
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    they weigh about 175lbs. so get your hernia gerdle ready[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    They are full time t-cases which means alot of wear on the front end. You can put in a part time conversion but instead of the hassle Id just go with a 205.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  4. Grim-Reaper
    7,385
    Atlanta
    In 1980 ALL trucks should have come with slip yoke NP205's. If the 80 does have a 203 it was probably swapped in. If it does have the 205 it should then jump on it. they are hard to find. $100 is a STEAL. Anybody that's knows what they have charges between $300-$500 for a NP205 with the adaptor. MAKE SURE YOU GET THE ADAPTOR!!!!!! They are expensive.
    THe 205 will have a plate with 3 bolts on the back side of the case. That's the easy way to tell a 205.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  5. jms0945
    Aug 22, 2001
    64
    Huntsville, Alabama
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    They might be heavy, but your guess of 175lbs. is pure B.S.
    come down around 125lbs. and we will talk #'s .
    okie doykie
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    OK I'll give ya 5lbs. it weighs in at 170...NP203 type:full-time, cast iron, chaindriven case Low range: 2:1 Applications: '73-'79 Dodge, ford and GM trucks...[​IMG]
  8. jms0945
    Aug 22, 2001
    64
    Huntsville, Alabama
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i got rid of one, it drove me nuts. they're always in all wheel drive, not four wheel drive, one wheel any wher, from what i figured. the shift pattern was something like:one front one back wheel high, one wheel anywhere high, one wheel anywhere low, one front one back low. i think. so if you have front manual hubs hubs you have to drive it in 4 hi all the time, otherwise it may send power to one wheel up front that is unlocked. it's confusing.
    Tork DSR
    I just got a winch, it takes the fun out of things.
  10. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    NP203 is a great case.. some will say not as good as the NP205 but its good none the less.
    its a full time 4WD case.. you put it in HI or LO for normal driving on pavement and stuff.. then the front and rear driveshafts can turn different speeds... you put it in HI-LOC or LO-LOC and its just like any other transfer case in 4wd.. the driveshafts are locked together.
    The coolest thing about the NP203 is that you can install a part-time kit which will give you 2hi, 2lo, 4hi, 4lo...... the 2lo is nice to have sometimes.. plus it shifts better than a NP205 in my opinion, and the shifter handle looks better. They are chain driven which is somewhat of a downside but if you replace the chain once you'll probably never have to touch it again. I will run a 203 over a 205 anyday.. especially since a 203 will mate a turbo350 trans so easily.. thats my opinion..
    mike reeh
  11. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i am going to tell you a secret you must swear not to tell anybody. I pulled my 205 off a 74 pickup with a 350 trans, honest. and it was bone stock, i swear.
    P.S. i have two wheel low, i just jon't lock the hubs.
    P.P.S. you're right the 203 shifter is sweet looking.
    Tork DSR
  12. chevyfumes
    Feb 24, 2000
    38,584
    266
    I have a 74 and it should have had a 205 I guess they must have run out and put in the 203[​IMG]
  13. jms0945
    Aug 22, 2001
    64
    Huntsville, Alabama
    well the K-5 im thinking about putting it into has a th400 trans
    not sure if it will hook up good or not
    i cant seem to find any info about the th400
    Michael
