NP205 10 spline to 27 spline?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by roostr3269, Feb 20, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I upgraded axles to from half ton to 1 ton and was trying to find a way to upgrade yokes for larger 1 ton u joints. I was told if i have the 10 spline NP205, i should just get the 27 spline 205. Is there a way of upgrading spline from 10 to 27. Any other input would be appreciated, thanx.
    live to wheel, wheel to live--1972 gmc jimmy 8 inch lift, 37" ssr's
  2. bigbadburb
    bigbadburb 1/2 ton status
    Nov 13, 2001
    176
    vancouver wa
    are you speaking of the front output and if so then a better choice would be a 32 spline which is the same as the rear so then you can use the same 1350 yokes front and rear
    72 subueban 44s,fi bigblock ,th400 doubler,etc,etc
  3. roostr3269
    Jul 2, 2001
    305
    michigan
    Yep thats the one. I got hooked up with some info today from a friend, thanx for the info.
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    ORD has some 32 spline front output shafts.
  5. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
