NP205-700R
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arq, Jan 17, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Does anyone know if the NP205 was ever mated with the 700R from factory???
    Cool group. This is my first time posting here. I spend most of my time over at Wulf's Den www.blazer-net.com
    thanks,
    ARQ.
    2-72K5
    1-71K5
    1-73
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Welcome to the board. From what I've seen, we're way more off road oriented at CK5. As for the factory matings, I sure don't think so but I could be wrong. I think all the 700 had behind it was a 208 and a 241. Once again, welcome aboard. And if you get a chance fill out your profile so we can see where you live, what you drive, what kind of beer you like, ect. haha
    Later, Bryan
    Durant, Ok
  3. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Howdy, and welcome!
    As far as I know the 205 was never behind the 700r4. But if you have a 205 that was set up with a TH350, it should be compatible with the 700 as they have the same spline count of 28. Where as a 205 that came off a TH400 would have the 32 teeth spline count. I currently have a 203/350 set up, but I'll be swapping to a 205/700 set up. I already have the 205, so when I'm ready I'll build up a 700. Not eveyone is a fan of the 700, but the low first gear is nice and I NEED the OD.
    It's not what you buy, it's what you build!
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Nope, no factory 700-205 combos. Look for a 1980 TH350 versioned 205 and its adapter. It should bolt right to a 700.
    ken
  5. k5kurt
    k5kurt Registered Member
    Nov 19, 2000
    10
    thorsby,AB, Canada
    yeh, i resently put a 700 back in my blazer. The 208 that originally came with the truck fit the th350 that i put in when i bought it, so i would imagine that the 205 would fit also(with the different spacers)
