NP205 and 700R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, May 19, 2000.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    OK, I must have seen this question asked a million times, but never really paid enough atention I guess. I am thinking about swapping my NP241 for a NP205, I need to know what all is involved, Does the 205 nedd to come from a th350? I think I need the crossmember as well adapters? Also will my spedo cable bolt right in? I know I will need a new output shaft in the tranny and new drive shafts, any thing else?
    Steve
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    There are a couple of different ways to go here. It would be best to find a 205 from a th350 b/c the splines would match the 700r4. Or you can swap a fine splined input gear into a 205 from a sm465. Or maybe you could get a coarse splined output for the tranny? I called ord and asked them. You definitely need the adapter and sleeve and the crossmembers. I am installing mine this weekend so I'll let you know how it goes and if the speedo cable bolts up.
    BIGJ
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    The t400 uses the fine spline 32, the t350 uses 27, also some early t400, the 465 uses a 10 spline.
  4. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    here is the easiest way, get an atlass!!!! (jk)
    89K5 payed 3k for the rig, spent almost 7k in the last 6 months on upgrades!!!!
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I have an '83 Blazer and wanted to stick in a 350 and a NP 205 but was told by two tranny shops that the 205 would not fit my Blazer. I didn't get into why not too much with them. Kind of wish I would've cos I had my hands on a 205 for 150 bucks. If anyone knows WHY a 205 won't fit into an 83 please lemme know.
    creepin and crawlin
    Jim
  6. BIGJ
    896
    Central Arkansas
    Just to give an update on the 205 swap. I dropped the tranny earlier last week and took it to get the short shaft installed. It was around $65.00 for the labor. The speedo cable does fit but the input for the cable was on the driver's side of the 205. The cable was originally on the passenger side when I had a 208, so I had to run it on the other side. You will also need 2 longer top bolts for the adapter where it bolts into the tranny. The bolts are 10mm. I also had to drill new holes for the crossmember.
    BIGJ
