NP205 and T400 adapter DFW tx
Discussion in 'Engine | Tranny | T-case' started by motofool, May 1, 2005.
  1. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    i pulled these from another members truck i pulled everything but the axles from under the truck bolts crossmember the works
    the transmission has had a recent rebuild
    i drove the truck before i removed these items and tested 4wheel drive
    im located in the DFW texas area moving to tulsa ok in 2 weeks
    450$ obo
    pics available
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I am interested. What year and model truck is it from? I am close by :D
    PM sent
  3. motofool
    Apr 7, 2004
    361
    DFW tx
    i think the truck was a 78
  4. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Did you get my PM? can you send pics?
    Do you know whether the NP205 has the long style female input shaft where it sticks out about 3.5 inches , or the short style that sticks out 1.25 inches? Or is the trans still attached? You mentioned the trans was rebuilt. Is the trans included?
    Thanks,
    Jeff
  5. motofool
    Apr 7, 2004
    361
    DFW tx
  6. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    I want it too, so put me in line if the other guy doesn't buy it.
    CASH IN HAND
  7. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    I'm gonna have to pass on this one. Not the right style case for me.
    thx,
    jeff
  8. chevy_muscle
    Mar 16, 2004
    103
    Murphy, tx
    Uh oh,,..... that may not be the right case for me too.
    ...... is the adaptor for the older style figure-8 NP205?
  9. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Where are you in Dallas ?
  10. dyeager535
    26,975
    Just an FYI, that's either a '90-91 case, or the output housing has been changed. Looks like round bolt pattern to me, that's '85+ IIRC.
    The slip yoke output housing puts that as a 1980 or later model, the VSS is '90-91 only, and that shifter handle is also a later model than a 70's piece.
    Wish you were closer, I'd love to have a spare. Perfect candidate to convert your truck to '90-91 electric speedometer cluster for anyones info.
  11. motofool
    Apr 7, 2004
    361
    DFW tx
    do we need a better pic of the adaptor ?
  12. badger red
    badger red 1/2 ton status
    Jul 30, 2004
    208
    south central KS
    Bill--I'm interested--sent you a PM.
    Jeff
  13. chevy_muscle
    Mar 16, 2004
    103
    Murphy, tx
    I'm going to have to back out of this. Thanks for the call.
    I need the later model version.
  14. dyeager535
    26,975
    I was initially sure that was a VSS on the output shaft, but is that a wire connector or is it a speedometer cable connector?
    If VSS, then at least that part of it is '90-91.
    If the adapter looks the same where it mounts to the transfercase as the transmission end of the adapter in the picture (round) then it's a round pattern 205. There was only that pattern and the "figure 8" pattern, so don't really need a picture I'd say, just confirmation of how the adapter is bolted to the case.
  15. j20m715
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    It looks to be an 80 model.
    The wires you see are for the dash lights (4x4) & (low).
    If you look at the rear output you can see thats its a slip yoke & that it is a cable driven speedo.
    It looks to be a figure 8 bolt pattern. The pic shows the round pattern that goes to the trans. The adapter is bolted to the t-case (looks to be a figure 8 style)
  16. dyeager535
    26,975
    You must have better eyes than I....I can't tell for sure that it's just not a crudded up VSS connector. Rear output can't be slip for 90-91? I know they were used up until the mid-late 80's, but I don't have the parts manual for 90-91.
    I just can't tell for certain on the adapter pattern, just too shaded for my eyes in that picture.
  17. motofool
    Apr 7, 2004
    361
    DFW tx
    i added some new photos as of today
    if you invert the dark ones you can see the bolts
    when i pulled the unit it had a regular speedo input in the 78 chevy it was in
  18. dyeager535
    26,975
    I concur then...that's the "figure 8" adapter, more than likely a 1980 piece.
  19. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Moto, would you consider selling just the xfer case? Pls let me know ASAP.
    Thx,
    jeff
  20. j20m715
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Hey Jeff
    I might be interested in the trans & adapter if the price is right :grin:
