NP205 Brake kit vs. Caddy Calipers
Discussion in 'The Garage' started by 73k5blazer, Sep 10, 2005.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Anyone to comment on the holding power of one vs. the other? (i did do a search) I need to decide this weekend if I should order the NP205 kit, or the caddy calipers and custom e-brake cables. The NP205 kit will probabably edge out a bit cheaper, but I just want a setup that works. Anyone ever hook up both at the same time?
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I would think that the 205 kit would hold better... while it only has 1 caliper compared to the two a rear disc setup would have, it also has the advantage of being in front of the rear axles gears, so its braking power is multiplied by the gear ratio. If you have low gears it should hold pretty well.
    j
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    While I don't have the caddy calipers, I have the "Large GM" calipers that TSM sells - they have a cable mounted parking brake. The brake works OK when adjusted, but is definitely not what I would call strong. I would also mention that reconfiguring the stock cable system to work, and to work without causing drag during flexing, etc, has taken me a few hours of work. Those problems would be avoided with the TC brake.
    Advantages? With extra ground clearance, less complicated setup, and less cost...I would probably go TC route next time. I do hear some people have clearance issues with the tub floor...
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i got the 205 kit for the from HAD and i am copy machining the kit for my two other trucks, only i am machining the parts out of stainless and titamium. the caliper will be ti., the disc is 316 ss only cause i dont have ti plate, the pivot pin is ti., and the hub adapter will probably be made out of cromoly. why you ask......... because i can, i love being a machinist. :D
  5. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Can someone explain the 205 kit? Who makes it, etc? I'm guessing it's some kind of mechanical caliper that holds a rotor that is connected to the output shaft of the NP205. I'm contemplating getting disk brakes for the rear of my rig, but I'm torn as to which calipers I should go with. I want the braking power and the ease of maintainability of the GM truck calipers, but I would like to have the parking brake that the caddy calipers afford. If I could have both by going with the GM truck calipers for the rear of the truck and using some kind of NP205 parking brake, well that definitely seems the way to go.
    ARAMP1
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Nobody talks about a driveshaft drum brake anymore :confused: Most applications over 1-ton use them.
    They have better static braking than a disc. It can't see it clogging up with mud to anywhere near the same degree as a drum brake at the wheel.
  7. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    The only thing you have to remember about the 205 brake kit is that if you don't have a spool in the rear axle and it is flexed out, the truck will have the possibility to roll via the differential. It's not a BIG problem, and could be fixed by putting the truck in 4WD, if it isn't already, but it is a safety concern.
    It is easier to use and, with the proper skidplate protection, would make for an extremely effective parking brake. I know I'd hate to strike a rock with the rotor and possibly break it, or even worse, the rear output shaft. :doah:
    Cost of HAD kit vs. cost of Caddy calipers, they're about equal. You HAVE to buy HAD's output yoke, and I'm not sure if that would involve getting driveshaft work done. I haven't done that much research on it.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I'm calling you when it's time to machine titanium portal housings for my Mog 404s!!!....
    Why? Because YOU can! :pimp:
  9. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would also be interested to know what all you have to get to make the driveline brake work. Is there a way to do it using your existing driveline, or do you have to replace it :confused:
  10. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I wrestled with the same dilemma. I ended up going with the large GM calipers from TSM. I then got custom cables made up by a co. called Custom Contol Cables down in SoCal. I just wasn't impressed by the quality of the "caliper" that went on the driveshaft. The disk looked good. The bracket looked good, but the caliper was hokey. I also had several people tell me that their holding ability was marginal. I had a hard time myself believing that this would hold my rig
    as strong as two of these:
    Having said that, I also solicited opinions here and found people who have them who recommended them. A big issue also was space and driveshaft length. The disk may sit high enough that you have clearance issues with the body. It also shortens just a small bit your driveshaft length increasing the angle. If you don't already have a steep angle, then no big deal. In my case, I'm already having to cut and re-weld the perches on my Corp14ff to correct the pinion angle. Since the rig is still in the backyard being finished, I can't say yet just how good the rear calipers will work. And yes, you pretty much have to modify your own driveline or buy one set up for it ala HAD. HAD's looks like this:
  11. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Any chance of a web address or info for HAD so I can check it out?... its not a good word to google!
  12. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    make me one for my 205 slomita man!!!...
    If you can make two you can make three :D
    cam
  14. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
  15. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    That looks more stout that the NP205 kit one. And only $30 plus 5 for the pucks.
    That's a great find!
    I ordered the cables for the caddy calipers, so I'll see how those hold. If I'm not satisfied, that go-kart caliper looks pretty good, still would need the special yoke and rotor from the kit, and youd have to fab your own bracket for that thing. Might be good though.
  16. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I wouldn't trust that any further than I could throw it, and with it only being a 6" rotor, I could chunk that pretty far.
    It's not much bigger than the yoke it'd be bolted to. I don't believe you'd get the proper leverage on it. I'd be even more afraid of the rotor "tearing" with that much weight behind it. Ya gotta remember, it's a go-cart, not a 6,000 pound truck.
  17. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    I realize were talking about alot of weight, but we're also talking holding the truck still, not about trying to stop it. I can roll the truck forward and back just by turning the driveshaft by hand, doesn't seem it would need much pressure to keep it from moving. Although my perspective is of a flat ground situation. I can't even remember the last time I had to use my e-brake. I never park on an incline here. Since I've sold my boat, I don't even use it at the launch. Granted this is probably less than acceptable, but I wouldn't think it would take much more to just keep the truck from moving.
  18. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I like the mechanical factor of the HAD set up. You sont ever have to worry about leaks or hoses etc. I dont have mine on yet (its only been 3 years :( ) but I am getting there.
  19. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Looks cool but thats like $370 for a parking/E-brake. And would then need to get shaft shortenned. I want one but thas alot of cash that could go to something else... like a front locker or... I stay away from hills without curbs and keep a "E-Brick" in the bed for just in case.
  20. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I gotta have an e-brake. One for safety, 2 for convience. I hate when I start my truck then I forgot something in the house, to have to shut it down, right after a cold start, to go in to get what I forgot. Or your on the trail and you want to hop out and check the next hole/obstacle, I wouldn't want to be shutting it down constantly. A reliable good E-Brake is a must, at any cost.
