NP205 Cossmember and adapter
Discussion in 'Parts & Trucks Wanted' started by AmericanFreak, Jan 11, 2002.
  1. AmericanFreak
    AmericanFreak Registered Member
    Jan 6, 2002
    40
    Shillington pa
    I need a Crossmember that i can bolt to my 86 blazer that will mount my Np205 that i just bought. Also i need an adapter that will mate it with my 700r4 trans.
  2. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Where are you located? Fill out your BIO it might help.
    Later Ed
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  3. AmericanFreak
    Jan 6, 2002
    40
    Shillington pa
    Im from Shillington Pa.
    86 Blazer Building it up has 35s right now add a leafs and blocks and fender trimmin
  4. crewcab
    crewcab 1/2 ton status
    Oct 14, 2000
    396
    i have a205 w/adapter plate,,drive sleev and cross member located in n.y. buffalo $200 plus shipping.i will let you know if i can find just the adapter plate most people dont whant to seperate. do you need the drive sleev that connect,s the tranny to the t-case the case i have is a slip yoke
  5. AmericanFreak
    Jan 6, 2002
    40
    Shillington pa
    awesome i need the adaptor plate, crossmemeber and drive sleve i have the case also do you know if the shift lever will go up through the stock slot i ythe floor or will i have to cut the floor out?
  6. jmeador74
    jmeador74 1/2 ton status
    Oct 31, 2001
    108
    Eatontown, NJ
    hey man... just to let you know... that if you want to mate the 700r4 to a np205 transfer... you would need the th350/np205 adapter... and either a short shaft tranny or a 2 in. spacer to go in between the tranny and transfer...
    the adapter and drive sleeve will only allow for 7/8" of stickout coming out of the tranny if you are looking from directly above it...
    I am just glad that I just bought a 700r4 already mated to the 205... I have yet to install it into my truck, but that is coming soon... hey I hope this info works out for you... if you need to know where to get a short shaft for the tranny just ask stephan from ORD or the 2 in. adapter as well... I think he sells both of them
    the shaft goes for 160 and the 2in spacer is about 60 I think if I remember correctly...
    72 Chevy Blazer, 327, SM-465, NP 205, 4in lift, 35 in tires
    Was About to put in 400 SBC/ 700-R4
    Now trying to go 454/ 400/ 205 setup
