NP205 Fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jkce457, Nov 25, 2004.
  1. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    What is the proper fluid for a 1985 NP205? Both books I have say ATF, but it looks like it has oil in it? /forums/images/graemlins/confused.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I believe 205's are gear oil. I know the older ones are. They books you have may quote the oil for an 85 as ATF for the NP208 cases that most 85's have.
    NP205's are gear oil as far as I know. 80w-90 or what have you.
    Harley
    Does the oil in there stink like gear oil. If so then it is gear oil.
  3. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    It definatly has gear oil in it now, but I wanted to confirm that it is the correct fluid. My 85 NP208 had ATF, and the books say that after 1980 all T-Cases take ATF? /forums/images/graemlins/dunno.gif
  4. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I have two 205's. The one in my 1980 K10, with manual trans, has gear oil. The 205 out of the newer blazer (88-ish and going in the 1979 K5) that was connected to an automatic and has ATF in it.
  5. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    So can anybody else confirm which it is?
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    205's are supposed to have gear oil. 208's (and pretty much all aluminum housing chain drive cases) take ATF. 203's take 30wt motor oil.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not completely true. In the later years GM spec'ed ATF for NP 205s for increased fuel economy.
    I'd put gear oil in it anyway.
  8. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    Well, it sounds like someone much have switched it to gear oil at some point. It seems to be working fine, so I guess I'll just change it out for some fresh gear oil for now.
  9. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I would think a 205 with ATF would be kina loud on the road but I have never tried it. I have been running 80w90 for years with zero issues.
  10. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    The 205 and 203 have had everything from 80/90, ATF, and 30 weight speced from the factory. 80/90 is the best to put in and if you want to try for a little better milage you can use synthetic 80/90.
    ATF would work but we are putting these things under more stress than they probably imagined for a stock truck would have so 80/90 takes that stress better.
  11. OrangeCrushK10
    Jan 25, 2003
    1,425
    What if your running it behind and Automatic Transmission?
    Any chance on them swapping fluids?
    i.e. Gear oil leaking into the transmission, or vice-versa?
  12. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    /forums/images/graemlins/thinking.gifHmmm... maybe that's why the gear oil didn't look quite right...
  13. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    this is a good question. My 1983 asks for ATF for my 205 but i have switched to 80-90w in order to better protect the bearings and gears. The ATF change was a feeble attempt to increase mileage. This however dries out seals and is not near as good at protecting gears and bearings. As long as the output seal on your tranny is good no fluid should swap between the tranny and the t-case.
  14. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It is very, very common for the tranny fluid to leak back into the t-case. That, along with mileage is the reason that they spec'd ATF in later years. The 205 will work just fine on ATF.
  15. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I have never been able to keep tranny fluid outta my 205 for very long. After a new seal it's ok for a while then back to normal. So I run same synthetic in tranny and 205. Amsoil Series 2000. That, and Mobil 1 in engine, and Mobil-1 gear lube in rearend, I would say gets me ~1 mpg gain.
  16. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I blew up the 208 (ATF) replaced it with a 205 behind TH400 - gear oil - 90W.
  17. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    I run 80W90 synthetic gear lube in my NP205 in my 1980 K5.
