NP205 FOR A DBLR
Discussion in 'OffRoad Design' started by RDRAGE, Mar 18, 2001.
  1. RDRAGE
    RDRAGE 1/2 ton status
    Mar 6, 2001
    177
    JANESVILLE, WI. 53546-5624
    FIRST, THANKS TO EVERYONE ON MY 700 QUESTION! I'M LOOKING TO RUN A DBLR AND HAVE FOUND IT ALMOST IMPOSSIBLE TO FIND A NP205 FROM A TH400 TRUCK. I KNOW OTHER 205 CASES CAN BE MODIFIED TO WORK (CHANGING BEARING & INPUT GEAR AND CUTTING THE CASE SO THEY FIT). HOWEVER IF I COULD FIND THE CORRECT 205 IT WOULD BE CHEAPER & EASIER. MY QUESTION THEN IS WHEN LOOKING FOR A 205 FROM A 400 WITH A SHORT 32 SPLINE INPUT, FLANGE TYPE FRONT OUTPUT, FIXED REAR YOKE (NOT SLIP) WHAT TYPE/YEARS TRUCKS DO YOU LOOK UNDER!? THE YARDS DON'T KNOW A 205 FROM A 241 AND CAN ONLY LOOK FOR IT BY VEHICLE AND I STILL HAVE TO LOOK AT IT BECAUSE OF DIFFERENT OPTIONS. I'M STARTING TO WONDER IF THEY EXIST W/THE ABOVE SET-UP! IF ANYONE HAS A HOLLANDERS INTERCHANGE NUBER FOR IT THAT WOULD BE PERFECT!!!!!! THANKS AGAIN FOR ANY HELP!
    www.trailrunners4x4.org
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    No idea on the interchange #, but application would be an 82 1-ton with about any motor and the TH400. That should give you all the right parts on the 205. The only other case available was the 208, and 1 tons didn't have them, except the military for some reason.
    Good luck with the search.
    Making the world better, one truck at a time.
    SW-ORD
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Only certain model CUCVs had the 205; M1031 Contact Maintenance Trucks, and M1028A1 / A2 Shelter Carrier "RATT Rig". The reason for the 205 was the need for a PTO. Sad part is they were all slip yoke. 'Not sure whether long or short shaft input.
