NP205 front output yoke/flange questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big_B_Murphy, Feb 13, 2002.
  1. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    I am nearly finished with a th700/208 to sm465/205 swap on my 85 K5.
    My big question is why is there a yoke on the front output of my 205. All other GM t-Cases that I have had were flanges. that includes 203's, 208's and 205's. This is my first one with a yoke. I have several questions.
    1. Can you run a CV joint with a yoke? On the driveshaft from my 208 the flange seems integrated with the CV joint, and the u joints in the CV are larger than the the yoke on the 205
    2. Were the spines different from ayoke 205 to a flange 205?
    I took the flange off my 208 and it has a larger diameter for the seal to ride on.
    3. Has anyone run into this before (I am sure someone has)?
    4. All Chevy 4X4's that I have owned have had CV front shafts, so I assume that I need one. Am I wrong to assume that??
    5. Does anybody have the flange that I need? I would hate to have done all of this to have a 2X4 K5!
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  2. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    If you have a yoke, you should have the 10 spline front output, and yes you can run a CV joint with that. I had that same output on my 205 with a CV front driveshaft, but have since swapped out the shaft for a 32 spline.
    Russ
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    with any luck that will be for a real spicer cv rather then the saginaw flange ones
    formerly 77chev
    still a jerk though
  4. Big_B_Murphy
    Dec 28, 2001
    159
    New Stanton, PA
    What is the difference between the the saginaw and spicer CV joints?
    The one I have, the flange to U-joint part is also connected to a ball in the middle of the CV joint. Is that enough info to tell what kind I have. Which one do I have?
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    The Yoke is the Spicer. This is how they came before about 77 or so. Later cases have the square flange, aka Saginaw.
    I have one of each. I have to say the Saginaw is a lot easier to take the shaft off because the Spicer's bolts are very difficult to reach.
