NP205 front output yoke spline count?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 20, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a 76 NP205 (uses yoke for front output.)
    Anyone know the spline count?
    It has the 1310 yoke up there and I'm thinking about going 1350.
    -- Mike
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i think it can be either 10 or 20something in that year
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The input shaft for the 205 is 10-spline, but I'm needing to figure out the spline count for the front output yoke.
    Anyone?
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I found this on ORD's site.
    NP205 front output shafts:
    Change your weaker 10 spline shaft to a stronger fine spline version in either 30 or 32 spline. Both the 30 and 32 spline are very strong, the practical difference is the 32 spline shaft has more yoke options available.
    30 spline front output shaft for NP205 - $110.00
    32 spline front output shaft for NP205 - $120.00
    So, I need a yoke with 10-splines, I guess.
    -- Mike
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it can be 10 or 30, i was off by a few.
    my early 77 is the 30 spliner so you should pull yours to be sure.
    i recall something about flanges not being available for 10 spline so if you have a flange it is 30
