NP205 how much play in....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LKJR, Oct 22, 2001.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    '71 NP205 with the front driveshaft off how much play should the splined shaft have in it, in and out, I can move mine about a 1/4" is this too much? Money is very tight right now should I mess with a rebuild kit on this?
    thanks
    Les
    Like em big and topless
    Excuse me...Would you mind removing your import from under my chevy?
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    tttt come on someone must have something to say
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Are you referring to the front output shaft on the 205?
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    yes the front shaft but with the driveshaft off of the tcase
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you say you can move the yoke/shaft in and out on the t-case side a 1/4", that's too much. Something is not right. There should be hardly any movement in and out. [​IMG]
    I would tear it apart (start with front output shaft first to check for possibilities) and rebuild the thing.
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    thanks bud
  7. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Is that with the yolk on or off? If your yolk is removed, that much play is probably ok.
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    with the yoke off, I figured there would be some...
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I am not sure how much end play there is supposed to be in that shaft, but a rebuild kit is not going to do anything to correct it if there is a problem. The problem would have to be with a gear or shaft. If the case runs and shifts good, and it doesn't leak too bad, I would leave it alone.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
