np205 leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Jan 28, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I was checking my 205 for leaks because of some oil on the ground and the only place that I seem to be able to find leaks is from where the shift rails come out of the housing. It seems to be leaking from both.
    Is this a common thing, an easy fix? It is leaking quite fast so I would like to get it taken care of soon. Especially with all the snow around here, I'm running in 4wd at all times.
    Thnx
    ~Max
  2. dyeager535
    26,979
    Looks like there are seals for them.
    '85-86 parts manual scans
    The part number for the seal LOOKS like an old one, but depending on the year of your t-case, I'd double check with the dealer or someone else.
    One other thing to check is the fluid level...if you have a leak between the t-case and tranny, it can force fluid out of the seals as the t-cas overfills, at least it has in my case.
  3. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Thank you, I checked the level in the transmission and it was a little low but not too bad. The t-case however was quite low.
