NP205 Leaks at the Speedo Fitting.....No Seals???
Discussion in 'The Garage' started by Greg72, Jan 21, 2003.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    OK, I finally got tired of seeing the constant dripping of fluid off the fitting for my speedo cable on the NP205. It makes a big mess underneath, and now that I've got the High Angle Driveline e-Brake....having fluid all over the adjacent caliper and pads is NOT an option!!! /forums/images/graemlins/shocked.gif
    On my transfer case there is a fitting in a "recessed" pocket on the cast iron case that holds the nut and what appears to be the speedo drive gear (just a slender shaft with a gear at one end....has a "J" marking on it)...the output feeds into a Stewart-Warner offset block that must be another gear "adapter" to correct for speedometer errors....it goes into the NP205 fitting on one end, and then has a standard speedometer cable fitting on the other.
    Here's the riddle:
    I've taken the whole thing apart, and can't find any evidence of a seal that's missing, or a place where a seal could be installed to keep fluid from escaping (no machined "seat" areas...etc)
    I've shown the parts to a couple of guys I trust, and they are bewildered that THIS is the way the factory designed it.
    Does anyone have the "answer" for how the oil is contained, and IF there is a seal available somewhere? So far the only advice I've gotten is to "pack it tight with Marine Grease" and hope for the best........ /forums/images/graemlins/crazy.gif
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Most I've seen have rubber oring around part that inserts into case.Should have groove around where it fits.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I thought only mine did this! It drips all over my VSS. Post up when you find a way to stop the leak
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    What's weird is that there really doesn't look like there was ever a provision on the gear driven shaft to seal it at all!!!
    I can probably show it to a machinist and have them "create" a way to install a seal, but I really want to hear if there is a factory part or solution to this!!!
    (Plus I don't want to spend out the a$$ for the machine work!) /forums/images/graemlins/grin.gif
  5. ZonkRat
    Jan 16, 2003
    1,003
    Poss use a flat seal similar to distributer seal? /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  6. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Mine leaks in teh same location. slow but steady.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    So does mine. I've considered goobering it up with silicon.
  8. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Is it leaking around the threads in the case, where the speedo adapter threads on, or where the speedo cable connects? When I rebuilt my 205, I used teflon tape around the threads on the speedo gear and drain/fill plugs. Not that it did much for me since my rear main is undercoating my rig.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  9. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Greg,
    Here is the answer. The shaft of the speedo gear has a small o-ring that seals the shaft of the speedo. The speedo shaft and the screw in piece are seperat. The only way to fix the problem is to replace the screw in piece. It's only available from the dealer. Have them look up the piece on the computer. It's should be a stock item at a large GM dealer, it's somewhere between 20 to 30 bucks.
    The speedo gears on our 205 only use this o-ring. And it's build into the screw in piece. Aslo check the shaft of the speedo gear input for wear. Once I did this, all leaks stopped. Hell I don't even run a speedo cable, just a VSS for the TPI. Hope this helps.
    Rob
  10. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Thanks Rob....I feel like I'm starting to get somewhere!
    Here's a photo of the actual parts I'm dealing with....can you be more specific about "where" the seal goes?
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Digging up this ancient thread...
    Greg- what was the result, what did you wind up doing? There is a single lip seal in my 205 speedo adapter, NOT an O-ring.
    I'm half tempted to pound it out and match one from McMaster...
  12. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
  13. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks Greg! I bring da suckage at te sirch:pimp:
    Anyhow- Discontinued, no longer available. You might find a NOS somewhere, good luck, I don't seem to have any:doah:
    So I'm on a mission to find a seal...
    Metal case, single lip, no spring.
    .620 bore size
    .403 shaft
    .185 thick (can be slightly thinner or thicker)
  14. dyeager535
    26,982
    191
  15. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
