NP205 mating to 700R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Sep 7, 2004.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I know this has been asked back when I used to post a lot, but I couldn't find anything in the search. I can't remember for the life of me whether I can take the NP205 from my '81 with a TH350 (this combo is from a '77) and mate it to my '87 700R4? Are the output shafts the same? Can I just take the NP205 and adapter and bolt it right up to the 700R4?
    Bo
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You will need a spacer or a different shorter output shaft for the tranny.
    Your TH350/205 adapter will bolt up to the 700R4.
  3. Liberator
    Jul 16, 2001
    276
    The adapter will bolt right up but the tranny output shaft is too long? I don't quite understand. I figured I would need a new drive sleeve at the most. I wasn't aware the tranny output shaft was too long.
    Bo
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I've heard of some guys cutting down the output shaft.I don't know how much spline is left if you go that route though.
    Never seen it done,just heard about it.
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    yeah, the shaft is too long, advance adapters sells a new one
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    use the spacer. It costs $50, it works, you dont have to tear down your entire tranny to install it.. and once installed your driveshaft wont be hitting your trannys oil pan either... /forums/images/graemlins/thumb.gif
    j
  7. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    mine doesnt hit the pan but there is about 2 c.h. clearance... /forums/images/graemlins/eek.gif
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    lol, whatever you do, dont ever jump your rig. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
    i run a deeep AL tranny pan and its not even really close to my HAD shaft. Im a big fan of using the spacer. Its cheaper and easier, doesnt get much better than that. /forums/images/graemlins/grin.gif
    j
  9. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone have any pics of where it would hit? does it matter if it comes with flat flange or yoke style front output.
    thanks,
    ARQ.
  10. Liberator
    Jul 16, 2001
    276
    Where can I get the spacer?
