Np205 mount question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AmericanFreak, Jan 11, 2002.
  1. AmericanFreak
    AmericanFreak Registered Member
    Jan 6, 2002
    40
    Shillington pa
    Got a question i have an 86 blazer with a 305 and a 700r4 trans. If i mounted a Np205 in place of my Np208 will the 4wheel drive shifter go into the same slot in the floor? or am i going to have to cut the floor to make it fit? The Np205 is out of an older Chevy, (late 70s) and is a fixed yoke rear ouput.
  2. dyeager535
    26,982
    191
    NP205 shifter comes out in a different spot. You can heat up and bend the 205 shifter handle to fit though, which is easy. it takes very little bending. However, you will have to drill/self tap new holes to screw the 205 shifter boot to the floor.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
