NP205 mounting
Discussion in 'The Garage' started by Ruff_ryda_420, Dec 16, 2003.
  1. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    in my hybrid project, i'm using a NP205 and SM465 setup, it came loose from my frame but is apparently the original equipment. can someone get a pic or explain how it mounts to the crossmember. i've got the two little mounts, but i thing i'm missing something else. do the rubber mounts go inbetween the T-case and the X-member, or do the fit in the groove under the X-member? i looked in all the books i have and nothing breaks it down clearly. thanks in advance.
  2. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    There should be 4 parts to your mounts (not counting the bolts).. The bigger C shaped pads go between the tcase and cross member, the small square ones go under the cross member in the groove.
