NP205 noise at freeway speeds
Discussion in 'The Garage' started by trailblazr81, Oct 5, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    OK so when I get up to my normal cruising freeway speed in my 73 K20 I can hear my T-Case making noise. Between 2500-3000 RPM depending on hills and how late I am for work. I hear it coming from the shifter area. The fluid is good, clean, and plenty of it. Is this just the sound of an old gear driven T-Case?? Seems to be working fine!! Or should I start saving money for a rebuild?? :doah:
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    My brand new rebuild does that; I gather it's just the whine of the gears. Mine is louder in 4WD and/or low, of course, and is amplified by my lack of carpet or other noise proofing.
    -- A
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    mine makes a grinding noize when i let off the gas. i hear its just the slop in the gears.
  4. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    Mine only makes noise if I have something in the cab leaning on the shift lever, I'll also hear it if I push slightly on the lever while moving. Try isolating the lever with some rubber washers on each side of it, and that should clear up most of the whine
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    happy old 205 sound if you ask me. mine did it to.
