np205/np208 difference in them?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ed1507, Mar 19, 2003.
  1. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    what is the difference between them and im i right the 208 is an alum case thats what mine has dont see any markings ?
    any one know where to find a cheep one ed. /forums/images/graemlins/k5.gif
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    208 is a little bigger and chain drive i think.
  3. K Cinco
    K Cinco Registered Member
    Feb 24, 2003
    6
    Tarpon Springs, Florida
    208is also shift on the fly....if you have auto lockers.... where i dont think a 205 isshift on the fly ...and also not alum housing
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    not sure, but i think most 208 were slip yoke and more 205's were bolt one type. Im stupid though, so dont take my word for it =(
  5. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    you got it... 205s are fixed yoke and 208s are slip yoke...
  6. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    208's are aluminum cased chain driven with a slip yoke.205's have a cast iron case and are gear driven some have slip yokes but most are of the fixed yoke design.low range in the 208 is 2.61 to 1 I think and the 205 is 1.96 to 1 /forums/images/graemlins/k5.gif
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    205: iron case, gear driven, fixed yoke rear output (unless its the freakish 1980 np205), 1.96 "low" gear.
    208: aluminum case, chain driven, slip yoke rear output and a 2.7-something low gear.
    the 208s low is nice, and the fact that its lightweight is nice too... the chain-drive system is debatable... what isnt debatable though is that slip yokes SUCK. Im ditchin my 208 for just that reason, the slip yoke is just a crappy design.
    j
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Can you acutally swap the output shafts to make the 208 into a fixed yolk? Just an ignorant question...
  9. 96chevy
    96chevy Registered Member
    Aug 19, 2002
    14
    Smyrna, TN
    Another annoying new guy question, but what do you mean by freakish 1980 np205? Is there a difference and if so how do you tell which one you have and what makes them different. /forums/images/graemlins/confused.gif
  10. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    1980 205's have a slip yoke rear driveline...
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I think Jesse at at High Angle was toying with the idea of making a SYE(slip yoke eliminator) kit for 208's. The prototype's were cool but mucho expensive...but to answer your question, no you can't simply swap output shafts.
  12. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I think the '84 205's are slip yoke also. My 84 K30 had a slip yoke on it.
  13. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I had a guy at a driveshaft shop here tell me that on my 208, that if my output shaft had a threaded hole in it that he could put a fixed yoke on it. don't know if he is right or not though, just going off of his word.
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    OK I watched for a while and now to sum it all up:
    the NP205:
    - cast iron case
    - gear driven
    - 1.96:1 ratio
    - fixed yoke 69-79 slip yoke 80 and on.
    - 10 spline male, 27 spline female , or 32 spline female input.
    the NP208:
    - aluminum case
    - chain driven
    - 2.62:1 ratio
    - slip yoke only
    - 27 spline or 32 spline female input.
    There are some ways to convert to fixed yoke but no kits to eliminate the slip yoke design.
    Driveline solutions has a yoke that you can bolt on the shaft after you drill and tap the shaft for a bolt.
    Each has it's strengths and weaknesses, from ratio, to weight to material to design.
    Each has it's place in our hobby.
    /forums/images/graemlins/thumb.gif
    Sorry for the typo, it was 2.62 not 1.62:1
    /forums/images/graemlins/rotfl.gif
  15. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I thought the 208 had a lower numerical ratio than the 205, as from stated in the other responses? /forums/images/graemlins/confused.gif
  16. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    No, the 208 has 2.62 low gear ratio which is lower gearing... higher numerically.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    affirmative on the 208s ratio. AFA the 208 having strengths... imo it really doesnt. If you want an aluminum/chain driven tcase there are MUCH better options out there. The 205 may not have the best ratio in the world, but if you beef it in a couple of places (input, front output) its as close as you are gonna get to indestructable... especially if you have a mild 350 like me. /forums/images/graemlins/smile.gif besides, its only a matter of time before 2.5t axles go in the K5 anyway, and with the stock 6.72:1 gear ratio, the 1.96 in the 205 will be just fine. /forums/images/graemlins/wink.gif
    j
  18. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Last post edited.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
