np205 Off of a turbo 400
Discussion in 'Parts & Trucks Wanted' started by ramjet gmc, Jan 27, 2002.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Looking for a np205 Off of a turbo 400 with fixed yoke and with the short input shaft
    Yes I am going for the ORD doubler I also have a np205 for a turbo 350 with a slip yoke if you may want a trade
    More info on what I am looking for short 32-spline female. This came with TH400 transmissions this shaft sticks out of the 205 case by about 1 1/4" and the male transmission shaft plugs directly into it. The proper shaft stick out from the back of the TH400 for this type of 205 input gear is about 4 1/2". This gear configuration is the one necessary to run our GEN2 Doubler kit.
    Yes most of you all ready know this but I thought this might help
    89 gmc jimmy 35" 10bolt front and back
    but the build up is on the way
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Man good luck. I looked forever for the right 205 is hard to find. If you have a chance to get the set up with a slip yoke then you should get it. Just call steve at o.r.d. and get a output shaft and a seal retainer. This would be a good time to change the frt. shaft to 32 spline also. GOOD LUCK.
  3. crewcab
    crewcab 1/2 ton status
    Oct 14, 2000
    396
    there out there.did you get my e mail
  4. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    I found one for myself so lets try to help ramjet. COOL!!
  5. ramjet gmc
    Dec 19, 2001
    3,370
    still looking anyone??
  6. crewcab
    Oct 14, 2000
    396
    have one but it is a slip yoke.have parts to convert to fix yoke.$475 plus shipping
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i need one
    Grant.
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  8. rocnwilly
    rocnwilly 1/2 ton status
    Sep 6, 2001
    146
    Ventura, CA
    Re: np205 Off of a turbo 400 *DELETED*
    Post deleted by rocnwilly
  9. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    rocnwilly,
    Sent you a PM. Did you get it?
    87 K5, 427/340hp BBC,4.56 D60 & 14BFF, NV4500, NP208, TSM rear disc's,
  10. ramjet gmc
    Dec 19, 2001
    3,370
    still looking /forums/images/icons/wink.gif
  11. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I don't know how much the slip yoke conversions cost, but I converted my 10 spline 205 to 32 spline for $300 with a full rebuild. Could be done for about 200 with out the rebuild, but you are half way into it so why not?
  12. ramjet gmc
    Dec 19, 2001
    3,370
    back to top
  13. James Rustyk5
    James Rustyk5 Registered Member
    Aug 18, 2001
    34
    30 minutes South of San Antonio, Texas
    I might have just what you are looking for but I Will not know If the input shaft is the right lenght till I look in the morning at the transfer case. I do know the one I have is a fixed yoke out of 80 3/4 ton sub that had a 400 trans.
  14. ramjet gmc
    Dec 19, 2001
    3,370
    that might be it pm me when you look thanks /forums/images/icons/wink.gif
  15. chrstphr
    chrstphr Newbie
    May 12, 2002
    3
    hey maybe this will help you out. ebay has 4 of them on this week. here are the item numbers:
    1828039907
    1828963011
    1829081307
    1828403737
    i would but one myself but all i need is the adapter for a 205 to 400. anyone out there got one?
  16. ramjet gmc
    Dec 19, 2001
    3,370
    Wow thanks for the help and did you see the prices good god very high
    ORD sell these and cheaper then the ones on ebay www.offroaddesign.com/transfercaseparts.htm but I was looking for less so I was thinking to go used thank /forums/images/icons/wink.gif
