NP205 on 1970 Blazer
Discussion in 'The Garage' started by tweed1122, Jun 29, 2006.
  1. tweed1122
    tweed1122 Newbie
    Feb 27, 2006
    3
    Seaford, DE
    I have a NP205 transfer case in my 1970 blazer that is original. I can't find any information on it. Does anyone know if it take 80W gear oil and if so, how much of it.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Id say yes to gear oil... and fill it till it comes out the fill tube.. that is what I do... :crazy:
  3. goldwing2000
    goldwing2000 Guest
    80W90 and i think it takes about 5.2 pints.
    But like Rootbreaker said, just fill until it comes out the fill hole.
  4. tweed1122
    tweed1122 Newbie
    Feb 27, 2006
    3
    Seaford, DE
    Thanks, I thought that's what I needed to do. there are two bolts one at the top and one at the bottom. I took the top one off and fluid came out and then more when I took the bottom one off. I was just a little confused when some came out of the top plug.
  5. goldwing2000
    goldwing2000 Guest
    There are three possibilities. Well, maybe four.
    Simplest: The vehicle may have been parked at an angle when you checked it.
    Or: If the fluid is hot, it will expand and cause the level to rise.
    Or: It may have been over-filled by the prior owner.
    Worst Case: You may be leaking fluid between your transmission and transfer case. Check the trans fluid level. If it's ok, then you're probably safe.
