NP205 Output shaft tolerances
Discussion in 'The Garage' started by folkenheath, May 18, 2006.
  1. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    I have been searching all over for this and can't seem to find the answer yet. Does anyone know the endplay and also the radial play tolerance for the NP205 rear output shaft when installed? I am trying to figure out how wore mine is and I can't find this info.
    Thank you.
  2. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The 205 endplay specs. are .002-.027, theres not really a given number for radial play.Use your own judgement,if the output is really wobbling around there you might want to investigate why.
    Rear endplay can vary between different 205s and for the most part is not really adjustable.
  3. folkenheath
    Nov 12, 2004
    4,269
    159
    Wisconsin
    Thank you very much. I removed the flange and did some more measuring, and everything looks fine I think. My endplay is on teh high side but I can't complain since it's 28 years old and still going strong. I think I will rebuild the thing in a year or so just so it's like new again.
    Thanks again.
