np205 output
Discussion in 'The Garage' started by MNorby, Sep 5, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    my 71 has a 1310 yoke on the np205. I need to find a 1350. Should most 3/4ton 70s trucks with 205s have them? Are there spline count differences on the rear output? Will 203 yokes work?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    All rear outputs of a 203 and 205 are 32 spline. 3/4s and of course 1 tons will have the 1350. GM no problem, but Ford is weird. I had a set of axles out of a 1 ton Ford, 60s front and rear, both yokes were 1310. I have an HP60 out of a 78 3/4 ton, and that has 1350s on it. Its a Ford thing, I don't understand. Don't even bother looking at a Dodge, they use some funky tiny joint, smaller than a 1310.
  3. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    well i found a pair of 1350 yokes from a divorced ford 205. Anyother quick Q, will by some crazy change the 205 yoke fit the 14ff? Didn't wanna pull the 14FF yoke off but thought if it did I could go to u-bolt strap retainers instead of strap and bolts.
  4. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    The 205 yokes wont work on the 14bolt,your gonna have to pony up and buy one of the new style ubolt yokes.
    Ford used alot of 1330 series yokes on there 205s which at first glance looks like a 1350 because they are the same width but have a smaller cap,might want to double check that.
  5. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    thought it was worth a try. Will check on the cap diams. was thinking that ujoint fit but am second guessing myself now.
