NP205 parts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alf4444, Jan 28, 2004.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Alright I finally have all the parts I need to swap my 203 to a 205 /forums/images/graemlins/grin.gif I think. Anyone wanna give some advice before I start, its going behind a 350/350. I'm running a 6" susp anyone know the leangth the dlines should end up being? It would be nice to be able to pull them and have them done before I start. Do I need to move the crossmember?
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    No you won't have to move the location of the crossmember but you will need a crossmember from a 205 (the bolt holes for the adapter mounting are closer together versus the 203..)(Well they are on mine at least..Went from a th350/203 to a 465/205 and the mounting holes for the adapter were narrower for the 205 Not sure if it is the same for the th350/205 but check first) /forums/images/graemlins/waytogo.gif
  3. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Can the holes be redrilled?
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Yes they can but they have to be oblonged like the 203 holes were..but double check( I am not sure though IMO it would be easier to get a crossmember form a 205) then use the old crossmember for a second frame brace...Look about 1-1.5 feet back fom the org location and you should see some other holes that will line up with the crossmember... /forums/images/graemlins/waytogo.gif
  5. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I did this long time ago and used the same crossmember.
