NP205 pinion nut removal
Discussion in 'The Garage' started by dodgedude99, Nov 4, 2005.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    ok whats the trick to getting these off????
    my dial calipers tell me its a 1 5/16" nut, but the only socket i can find that size is in 3/4" drive, and that wont fit between the ears of the yoke, the walls on it are too thick.
    case is off a '79 1/2 ton.
    FYI i had the same problem with the yoke on my front Dana 60, but that i just cut the ears off with the torch before i installed it, the 205 is all bolted up and filled up.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You need to find a thin wall socket, not sure on the size though. Might want to call Offroad Design, they should know.
  3. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    You may need to get one of the cheapest made sockets you can find. (harber freight or the zone should have some that have thinner walls). Even in 3/4 drive. There are sockets that will fit, you need to bring your calipers with you and check them out before you buy.
  4. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I didn't need a thin wall socket to remove the nuts on my 205... maybe my sockets just have thin walls to begin with... I dunno.
    j
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought my socket at Napa, works great.
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I couldn't find a thin wall at any of my local parts stores so I bought an extra one and had a friend put it in his lathe and take material off till it just fit.
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The socket from my 3/4" harbor freight set fit just fine with no modification.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Use a chrome socket, not an impact. Impact sockets, generally, are thicker.
  9. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    the socket i was trying to use was a chrome one, not impact.
    but thats neither here nor there, i was able to get it off with a 12 point box wrench.
    my k5 has a driveshaft in it for the first time in 2 years. :D
    now if i could only finish running the brake lines, finger out the wiring, and swap the hydroboost brake pedal.
