NP205 problem or brain fart??????
Discussion in 'The Garage' started by Thumper, Mar 6, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Ok, need some help here.
    I was putzing around today on the rig and decided to go for a little test drive around the block. Everything was good till I grabbed the t-case handle and tried to slip it into 4hi at about 20mph. All I got was grinding... I had to totally stop before I could shift it into 4hi. BTW, this is with the hubs unlocked. Now... I am almost positive I have done this before and been able to. A buddy stopped by and said that there is no way I should be able to without the front shaft turning ie: hubs unlocked, but I still think I have done it before.
    Is there a possible problem with my 205? Or am I haveing a brain fart and on crack??
    I feel like Im losing my mind! Help! /forums/images/graemlins/yikes.gif
    Mike
  2. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    I know it works fine w/ the hubs locked. It would make sense that you wouldn't be able to do it w/o the hubs locked because the front won't be spinning. That means there is nothing to sinkro the gears.
  3. Thumper
    1,582
    Alberta Canada
    I think thats where I am confusing myself... because it does make sense that you shouldnt be able to. But I know I have never heard any gears grinding before.... maybe I havent ever done it... dunno any more. hehe.
    It may be the fact that I have never went to 4hi... I have used 2lo before but you have to be stopped to engage that. Oh well... guess its not a problem. Whew. /forums/images/graemlins/woot.gif
    Mike
  4. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    I run my hubs locked all winter and I shift mine in and out at about any speed with in reason.I just back off the gas and shift it in or out it don't seen to mine.
    Maybe with the hubs un locked the front not turing might cause a grind till the drive shaft ketches up.sure you didn't try to grab 4l. sometime between our trucks at work and mine I wan't to shift the transfer case wrong.
    Hell sometimes after being in the loader all day I'll grab my turn signal and try to shift thats the side the loader shifts on . /forums/images/graemlins/whistling.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are no synchros in a 205 so it will grind going from 2Hi to 4Hi unless the front hubs are already locked in. /forums/images/graemlins/thumb.gif If the hubs are locked then you can switch back and forth easily. /forums/images/graemlins/cool.gif
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I agree with Harry.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    with hubs locked you can shift into every gear position 'on the fly'
    some 205s have syncros, auto hub versions IIRC
  8. Blazer1970
    1,600
    Old Mission, MI
    true
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Don't try shifting to low range on the fly! /forums/images/graemlins/yikes.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    why not?
    it is just a transmission with about 2:1
    so you either double or half your rpm to shift
    as long as you do it clutchless it isnt hard
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive don't it many times up to 20mph
    just with an auto stift into neutral first, push clutch in with stick
    ive only done it with 208s though /forums/images/graemlins/dunno.gif
