NP205 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MKeen, Aug 14, 2001.
  1. MKeen
    MKeen Registered Member
    Jun 20, 2001
    20
    Tulsa, OK
    78 Blazer, with a NP205. Shifting it around from 4wL,N,2WH,4WH and back is smooth and fairly easy. However, after wheeling around in 4WL for awhile it is sometimes very hard to shift back to 2WD. The linkage does not appear to be sticking and the oil level in the case is good. Is this normal or anything I should look at?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    What you're experiencing is gear wind-up - perfectly normal for an all-gear part-time transfer case. Don't force the shift lever! Apply light pressure as you drive slowly in a zig-zag pattern and it will pop out effortlessly.
  3. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Also try backing up slowly while shifting to 2wd.
    Good things come in small packages. Good things come to those who wait. So, if you're waiting for a small package, that must *really* be sweet.
