np205 rear output flange?
Discussion in 'The Garage' started by crawlink5, May 21, 2004.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Did a search but found everything on the front output.
    I want to use a front driveshaft in the rear and cut the frame to fit length. What can I do about a flange for the rear?
    1979 chevy 4x4 pickup 465/np205.
    Thanks,
    Doug
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    How about using a rear yoke and matching double-cardan shaft from a 78-79 Bronco?
    Or... (I think it'll work - haven't tried it /forums/images/graemlins/thinking.gif )
    Take a spare/busted rear yoke, and machine it down so all you have left is tube with an internal spline. Make up a plate with the same bolt pattern as the driveshaft; and cut a hole in it to friction-fit with the tube. Heat the flange, chill the tube, put them together, and weld around it.
  3. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    I think I like the Bronco idea best. Except for trying to find one of these. Was 79 the last year for 205 in a bronco? I think from my search that all outputs to the rear was 32 spline?
    If I get my hands on a flange to fit I'll get the bolt pattern to work if I have to have it machined.
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    79 was the last year for the 205 in the Bronco, but they continued with the fixed yoke on the NP208... and I think even in the BW1345. I dunno if these are the typical 32-spline, or Ford's 31-spline. /forums/images/graemlins/dunno.gif
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Jesse @ High Angle has his own 205 rear flange... Got one on my buggy, just don't have a good image of it.
    Marv
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    does it fit the stock 1310/Saggy CV flange or just the 1350 ford CV flange that he sells?
  7. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Fits his 1350....
    Marv
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    looks like the easiest way is to convert to a 32spline front outputshaft and use spicer CV rather then the flange
  9. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Thanks - I'll be looking for one.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    look under fords or what ever u2slow tells you to look under
  11. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I have a flang on the back of my 205 with a caddy cv, i thin the shop that got it for me said it was a Dodge flange, but not sure, it wasn't a custom application , in was a stock offering on something, maybe call a reputable shop and ask them to find the application for a 32 spline flange output yoke, the shop that did mine a million years ago was Cannon engineering in North Hollywood, sorry dont have the number anymore, but if you can find tha yoke of which i speak, it has the same bolt pattern as the front saginaw cv that came stock in blazers.
