np205 rebuild help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue Meanie, Apr 15, 2002.
  1. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    i have just aquired an np205 transfer case. i am not too sure of the condition of the internals but am planning on rebuilding it anyway. is there any good tech sights that would have breakdown info and parts listings? and if so, could someone please point me in the right direction?? thanks
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    The only thing a 205 might need is bearings. and pinion seals. If the bearings on the shafts seem tight I wouldnt bother with a rebuild.
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    4xheaven in NY(1-800-800-1679), has a complete rebuild kit, bearings, seals, gaskets for about $130, they also provide tech support. Also, Steven at ORD can help to.
  4. Blue Meanie
    Apr 12, 2002
    61
    southern New Jersey
    sounds great. thanks for the info!!
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I did it this previous weekend...some of the snap-rings are kinda a pain but it is pretty simple...You also need a couple BIG sockets (like 1-1/4" fo rhte front output yoke and a little bigger one for the idler shaft locknut and the rear output yoke..)Not too bad though...also, the roll pins that hold the shift fork to the shift rail...those were tehe hardest part of the entire rebuild for me...
    Chris
  6. Blue Meanie
    Apr 12, 2002
    61
    southern New Jersey
    got the sockets but i don't know if i am going to be getting in over my head. i can fix stuff if i have to but get a little lazy when it comes to stuff i don't HAVE to have done, you know. this will be my first time doing this and i have a good friend that seems to know how to fix anything (nothing has broke yet). i guess we will see
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    My chiltons guide had a great section about the 205. It has an exploded view and step by step instructions to disassemble it. BEWARE of the needle bearings and pilot bearings...they will fall all over the place. I lost 2 pilot bearings and had to "borrow" a few from a buddy's 203 he had laying around...Other than that it is easy.
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Speaking of needle bearings, the best tip I've heard with them is to leave a couple out while your assembling the unit, then once you get it together then take a hammer and a small punch and tap the remaining needle bearings in. But I've never seen the inside of a 205.
