np205 rebuilder gurus,,, some help with idler shaft
Discussion in 'The Garage' started by camiswelding, Apr 1, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Have my 205 all apart but i cant get the idler shaft to budge... and Im using alot of force... GM book says to use a soft faced mallet and a driver tool (I used a solid piece of round 1 1/2 inch stock) and a sledge ... and it wont budge. Project Burly Burb folks used an air hammer but Im striking as hard or harder than any air hammer.It was suggested I use a rosebud tip to heat the case to 150 degrees about 2 inches away from the shaft (not the shaft) and see if that would help move it.
    Anyone have experience with an immovable shaft and what you did to overcome it...I dont want to hurt the case/shaft by too much force... or heat unless I really have to use it
    thanks
    cam
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I am sure you already know which way it comes out but just in case you don't. The idler shaft is removed through the 3 bolt cover on the rear of the case so you must hit it on the threaded side. I just use a BFH and once it starts to move it will come out easy. /forums/images/graemlins/thumb.gif
  3. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    yeppers... front to rear /forums/images/graemlins/rolleyes.gif
    cam
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    make sure the 3-bolt cover is off on the back and take the nut in the front off and get whack happy...Make sure teh input and output gear clusters are out FIRST...
    Chris
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Mine was stubborn too, just kept pounding, eventually it came out. mushroomed the hell out of my brass drift too /forums/images/graemlins/blush.gif
  6. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    205,,, update..got it, needed wife power
    you all made me confident so just I went out and really whanged on it mushrooming the drift( as another poster described) and out it fell after 10 whacks with momma holding the drift and me playing muscle man on the sledge,,,
    now thats trust... I think she wants a new z71.. shes tired of being mechanic trainee
    thanks
    cam
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Re: 205,,, update..got it, needed wife power
    now thats trust...
    Shes got BALLS. I don't even hold the punch or drift myself unless I am holding it with a pair of vise grips.
