NP205 seal part numbers needed "Updated Found them"
Discussion in 'The Garage' started by cegusman, Feb 5, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    NP205 seal part numbers needed \"Updated Found them\"
    Does anyone have the part numbers for the:
    Front Output shaft seal
    Rear output shaft seal
    The 2 shift rail seals
    Am I missing any othe seals? The 205 is mated behind a sm465
  2. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: NP205 seal part numbers needed
    Found them:
    GM Part Numbers
    Front output shaft flange washer: 14022212
    Front output shaft bearing seal: 465483
    Shift rail seals 2 required: 3979626
    Rear output shaft flange washer: 14022212
    Rear output shaft bearing seal: 3967876
