NP205 Shift pattern?
Discussion in 'The Garage' started by chvyhs, Nov 26, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I'm having problems with 2wd high so I need to figure out it I'm doing something wrong here. What is the shift pattern for a NP205? I had to make my own shiter plate (between the shift rods) because my tcase didn't come with one and I'm not sure I got the shift pattern right or I made the holes in the shift plate at the right distance.
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    should be
    4-low
    neutral
    2-high
    4-high
    I may have a couple shift plates if you'd like one. Just let me know and I'll check my collection of parts. /forums/images/graemlins/thumb.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    should be
    4-low
    neutral
    2-high
    4-high
    That is correct sir.....with 4-lo being close to the dash. /forums/images/graemlins/waytogo.gif
  4. chvyhs
    Feb 12, 2001
    1,469
    Thanks, now I'm going to pull the shift rods and check to see if I got the shift plate lined up properly with the grooves in the rods.
