NP205 shift rail seals
Discussion in 'The Garage' started by moneypit, Apr 16, 2005.
  1. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Anyone got the seal #?? Can these be changed on the truck without removal of the rails? Both of mine seem to be leaking pretty good now. Since I have the custom doubler xmember/skid off, it is the time to fix the leaks... :D TIA
  2. dyeager535
    26,977
    I won't guarantee the accuracy of this number, the parts manual doesn't show both seals, (nor both shift rails lol) but this LOOKS like it:
    Seal, Shaft, Oil 3979626
  3. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Thanks I will try that.
    Anyone know if they can be removed/installed from the outside, still in the truck??
  4. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I can't think of a way to do it still in the truck. When I did mine, I knocked them out with a punch from the back side, after the rail was removed. There's just no room around the shaft and bore to get anything in there to pry with.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yes they can be changed with the T-case together and in the vehicle as long as you don't have the early 205 which has a welded bar on one of the rails. Also you will need enough room to use a piece of pipe or a socket to tap them into place. To remove the old seals just use a screw driver and get it between the shaft and oil seal and carefully pry it out making sure not to nick or scratch the shaft.
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I have 2 extra seals from a kit. Send me your address and I will get those out to you. :D freebie :cool1:
  7. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    You guys are awesome. Thanks for the info...
